width60%
V-Ray Vision is a real-time viewer that can be used in any project set up for V-Ray rendering. It is a lightweight “game engine” (rasterizer) that does not currently use any type of ray-tracing. Due to its speed, it can serve as a powerful alternative viewport that provides better lighting and material representation as well as camera animation playback controls.
In addition to its main function as a viewer, V-Ray Vision can produce spherical panoramas and quick output of both still frames and animation sequences. It comes with its very own auto-exposure, tone mapping, and color correction options.
When V-Ray Vision is launched, it automatically loads the current Rhino project and starts an interactive session. This means that while it is running, a live link is established that sends to the viewer all updates made to the Rhino scene.
Stopping the live link, by either clicking the toolbar's V-Ray Vision button or any of V-Ray's Render buttons, ends the connection but does not clear the loaded scene. To stop V-Ray Vision, close its window.
In addition to loading scenes directly from Rhino, V-Ray Vision is able to load .vrscene files directly. In this case, in order for the changes to be displayed, the source file has to be reloaded.
See the V-Ray Vision page or the Courseware page for more information.
width5%
width35%
UI Paths
UI Path: Vision button
width5%
width35%
UI Expand
expandedtrue
title
||V-Ray Toolbar|| > V-Ray
Rendering > V-Ray Vision
Image Added
width40%45%
||V-Ray Toolbar|| > V-Ray Visionbutton
Image Removed
width40%
(left-click) > Starts V-Ray Vision and begins a session.
||V-Ray Toolbar|| > V-Ray Rendering > Vision (right-click) > Configures V-Ray Vision before starting and beginning a session.
Image Added
width5%
 Image Removed
V-Ray Vision Menu
width60%
Enable Proxy LOD – Enables the LOD switching for Proxy Mesh assets. The full mesh is visible up close, whereas the proxy preview mesh is displayed in distance. Note that both share materials.
High quality Cosmos Assets – Displays a high quality version of each Cosmos asset close to the camera. Cosmos assets have multiple levels of detail and by default Vision loads lighter meshes for increased performance. When this option is enabled the highest level will be used when the camera is close to the object. Note that enabling this option might have major impact on performance and loading time depending on the assets used. The scene will be automatically reloaded when the option is changed which might take a while depending on the project's complexity.
Shadows Quality – Controls the quality of Sun, Directional, Omni and Spot lights. From the drop-down you can choose from:
Low – Low quality shadow map filtering is used. Shadow map size is decreased during scene interactions.
Medium – Medium quality shadow map filtering is used. Soft shadows are disabled.
High – High quality shadow map filtering is used. Soft shadows are supported. Changing the Sun size affects the shadow softness.
Temporal Anti-aliasingEnables a higher quality anti-aliasing method. Note that this is a compute expensive option and needs multiple frames to achieve good-looking results.
Auto Exposure1 – Enables auto exposure.
EV Compensation – Multiplies the exposure value of the camera or the value calculated by the Auto Exposure (when active). This option can store two independent values based on whether Auto Exposure is active.
Fly Mode – Changes the view navigation mode. Use the W, A, S, D, Q, E keys on the keyboard to move around. Holding down Space temporarily increases the movement speed. Hold the Left Mouse Button to look around
Fly Speed (m/s) – The movement speed measured in meters per second. Only has an effect in Fly mode.
Mouse Sensitivity – Changes the mouse speed when looking around in Fly Mode.
Smooth Movement Delay – The time it takes the camera to gradually cease after being moved during Fly Mode. Calculated in seconds.
Automatic IBL Sun – Automatically adds a directional light based on the brightest spot in an HDR image. The option has no effect if the project Sun is enabled. It is not recommended to enable it if there is no single distinct bright spot in the image used for lighting.
Ambient Light Mode  Enables the ambient lighting mode. This mode can be used to remove the blue sky tint from interior renders. When enabled, the project's environment will remain visible in the background but will no longer affect the diffuse indirect illumination and the reflections. An ambient white/gray color will be used as indirect environment. Note that the state of this parameter will not be saved with the project and has to be manually set.
Ambient Light Intensity  Controls the intensity of the ambient lighting. Note that the value of this parameter will not be saved with the project and has to be manually set.
UI Text Box
typetip
Ambient Light Intensity value between 100 and 200 is sufficient for interior renders when using Sun and Sky.
width5%
width35%
width60%
Output Mode - Specifies the type of the exported image. Note that VR Cubemap output in 6 separate files is not available for video export.
Image - Exports a still image.
Image sequence - Exports a sequence of images.
Video - Exports a single video file.
Camera Type
Standard – Uses a standard pinhole camera.
VR Spherical Panorama – Uses a spherical panorama to save the image.
VR Cubemap 6x1 – A cubic/box camera with the cube side arranged in a single row.
VR Cubemap 6 images – A cubic/box camera with the cube sides saved as separate images.
UI Text Box
typenote
Note that in Image sequence and Video modes only Standard camera and VR Spherical Panorama projection are supported. Some screen-space effects are disabled in Video mode to avoid artifacts.
File - Specifies the output file path.
Image Format - Specifies the output image file type.
Resolution Mode
From Vision Window - The window size determines the output image size.
From Project - The image size specified in the host application or the V-Ray scene determines the output image size.
Output Resolution - The final output image resolution. Note that the size multiplier value is also take into account.
Size Multiplier - Multiplier for the base resolution. Note that there is a hard limit of 8192px along the long image size to avoid video memory issues.
Animation FPS - Controls the number of frames per second when exporting sequences.
Frame Delay - Specifies the number of frames that each animation frame is rendered for. Some effects need more than one frame to be resolved to final quality. For example, the Temporal Anti-aliasing benefits from longer delays.
Export – Exports a still image if Animation is disabled. Exports an image sequence or video if Animation is enabled.
width5%
width35%
These shortcuts navigate through V-Ray Vision.
Shortcut
Description
Ctrl + Space or Ctrl + O
Opens a .vrscene file.
Ctrl + Backspace or Ctrl + N
Clears the scene.
TabChanges the camera navigation mode.
Left-click
In Orbit mode, it allows to orbit.
In Fly mode, it allows looking around.
Right-click or Scroll
In Orbit mode, it allows zooming.
Middle-click
In Orbit mode, it moves the camera left and right.
W, A, S, DIn Fly mode, allow for moving around.
Q, EIn Fly mode, allow for moving up or down.
SpaceIn Fly mode, it temporarily increases the movement speed.
Ctr + '+'
In Fly Mode, it increases the movement speed.
Ctr + '-'  In Fly Mode, it decreases the movement speed.
CResets the camera.
F12 Shows or hides the toolbar.
Shift + Left-click
Moves the Sun.
Up/Down – Altitude
Left/Right – Azimuth
Shift + Right-clickUp/Down – Changes the sun intensity.
Shift + Middle-clickUp/Down – Changes the camera exposure.
F5Resets the sun position and the lighting changes so to match the original scene state.
FAQ
Does V-Ray 5 include Vision?
• The technology used in Vision (rasterization) is fast but limited in quality and number of effects that can be supported.
• Most of the common material parameters used in V-Ray are supported in Vision. Some are still unsupported and hence you’ll see some differences in the way surfaces appear.
• Vision is also still not capable of evaluating the global illumination in the scene. As a result closed interior spaces would be illuminated incorrectly in most cases. Calculating many light bounces is required for better results.
• Chaos' main goal with Vision is to give a real-time experience keeping a high framerate. Vision is in active development, so the supported features are subject to change.
Footnotes
1- Note that when Auto Exposure is enabled, sizeable very dark or light portions of the buffer (e.g. completely black background surrounding a model), might produce an exaggerated exposure value adjustment.
Anchor
2
2
