Delete Particle | tun_act_op_del – When the condition of the Tuner passes for a particle, it will be deleted. If this action is selected, Change Particle Channel and Affect By Forces will have no effect. Note that this is superior to the Clear Inside option from the PhoenixFD Per-Node Properties because it can also work for particles outside the simulation grid.
Change Particle Channel checkbox | tun_act_op_chan – When the condition of the Tuner passes for a particle, you can choose which of its particle channels will be changed and how:
