This page provides information on the Multi Matte Render Element, which creates red, green, and blue selection masks based on an object's Object ID or Material ID.
width55%
With the Multi matte Render Element, only three colors are possible: red, green, and blue. In comparison, other matte render elements can include a multitude of many colors to represent each material or object in a scene with a different color. With Multi matteМatte, a single R, G, or B channel can be used directly as a matte, eliminating the step of selecting the color in the compositing software. This ease of use makes Multi matte Мatte a popular choice for compositors.
The Multi matte Мatte Render Element includes anti-aliasing.
To represent all the objects or materials in a scene with just the available red, green, and blue colors, several Multi matte Мatte Render Elements can be generated for a single rendering, each with different Material ID or Object ID settings.
UI Path: ||V-Ray|| > Render Elements > Multi Matte ID
width5%
width40%
Multiexcerpt include
MultiExcerptNameAddBackground
PageWithExcerptAtmospheric Effects RE
How to add a render element to a scene
width55%
Mask Type – Specifies how the mask is generated:
Separate Channels – Considers all three Red, Green, and Blue Ids.
White
– Creates a mask only for the objects with the specified id Id.
Enable Deep Output – Includes this render element in deep images.
Id – When Mask Type is set to White, you can specify the id of the object to be masked.
Red/Green/Blue Id – When Mask Type is set to Separate Channels, these parameters set the ID used for the respective channel.
ID Source – Specifies how the Red/Green/Blue Id Ids are read.
Object ID – Multimatte considers the Red object ID, Green object ID, and Blue object ID values to be the Object ID and renders the R, G, and B channels accordingly.
Multimatte ID
– The Red, Green, and Blue Ids are considered to be as the Material IdID.
Affect Matte Objects – Determines whether to include matte objects when generating the render element.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Mode – Selects whether to include or exclude the specified objects in the list.
Exclude Red/Green/Blue Channel Objects – Creates a list of objects/materials excluded from the respective channel.
Include Red/Green/Blue Channel Objects – When enabled, considers the Exclude List Red/Green/Blue as an inclusive set. All objects/materials not mentioned in the list are not rendered with this render element.
width5%
width40%
