Displacement mapping is a technique for adding detail to geometric objects without having to model it first.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Fur
Fur
The Fur option creates a simple procedural fur at render time. It is commonly used for simulating grass cover or textile fibers.
Textboxcard
PageToInclude
System Requirements
CardPageLink
Proxy Mesh
Proxy Mesh
The Proxy Mesh imports geometry from an external mesh, which only loads the full details at render time. The geometry is not present in the model and does not take any resources.
Textboxcard
PageToInclude
Installation
CardPageLink
Proxy Scene
Proxy Scene
The Proxy Scene imports a .vrscene file as a proxy. Containing geometry, materials and lights, these files are render-ready and are fully loaded only at render time too.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Scatter
Scatter
The V-Ray Scatter creates instances of objects using the surface of another objects to generate points.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Decal
Decal
