Floatingpagetoc
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1000px
Columns1repeat(3, 1fr)
Columns1width1540px
Columnsrepeat(4, 1fr)
Columns2width1290px
CSS Stylesheet
.UIImage {
max-width:650px;
margin-left:auto;
margin-right:auto;
This page offers information about the Lights tab in Chaos Vantage.
The light tab offers properties for the environment setup as well as a list of all lights in the scene and their properties. This includes lights imported with a .vrscene file.
UI Text Box
typeinfo
You can use the right mouse button click to reset the parameters numeric values to defaults.
width65%
Environment mode – Specifies the mode which will be used for scene lighting.
Texture – Enables the use of an environment texture for lighting. When this option is selected, Load environment, Clamp to 1 and Rotation parameters appear.
Solid Color – Enables the use of a solid color for lighting. When this option is selected, Environment Color parameter appears.
Physical Sky – Enables the use of an sky texture for lighting. Available only when imported .vrscene has VRaySky texture. When this option is selected, Sun light parameter appears.
Load environment – Loads an image for Environment. This option is available only when Environment mode is set to Texture.
Flip horizontally – Flips the environment image horizontally. This option is available only when Environment mode is set to Texture.
Clamp to 1 – Clamps the colors of the Environment texture to a value of 1. This option is available only when Environment mode is set to Texture
Rotation – Specifies a rotation angle in degrees for the Environment texture. This option is available only when Environment mode is set to Texture.
Intensity – Specifies the intensity of the Environment lighting.
Enable Fog – Enables aerial perspective fog to be applied in the scene.
Fog visibility range –Specifies the distance in km at which the fog has absorbed 90% of the light coming from objects behind it. Lower values make the fog appear denser, while larger values reduce the effect.
Fog height – Specifies the height of the fog layer in meters.
Fog start distance – Specifies the distance from the camera at which the fog starts.
Fog max opacity – Specifies the maximum opacity of the fog. A value of 1 means the fog will be completely opaque, while 0 means the fog will be invisible.
Fog color – Specifies the color of the fog layer.
Enable Fog 2 – Enables a second aerial perspective fog to be applied in the scene.
Fog visibility range (2)–Specifies the distance in km at which the second fog has absorbed 90% of the light coming from objects behind it. Lower values make the fog appear denser, while larger values reduce the effect.
Fog height (2) – Specifies the height of the second fog layer in meters.
Fog start distance (2) – Specifies the distance from the camera at which the second fog starts.
Fog max opacity (2) – Specifies the maximum opacity of the second fog. A value of 1 means the fog will be completely opaque, while 0 means the fog will be invisible.
Fog color (2) – Specifies the color of the second fog layer.
Enable Lights – Enables/disables all the lights from the scene. It provides a global override of intensity for all the lights in the scene.
Environment Color – Specifies the Environment color. This option is available only when Environment mode is set to Solid Color.
Sun light – Specifies which Sun light in the scene will be taken into consideration when computing the appearance of the sky. This option is available only when Environment mode is set to Physical Sky.
Background – Specifies the mode which will be used for the background. Note that the Background texture is not used for lighting and glossy reflections.
Same as environment – Uses the specified Environment source.
Solid color – Uses a solid color for the background. When this option is selected, Color parameter appears.
Image – Uses an image as a background. When this option is selected, Load background, Mapping and Rotation parameters appear.
Color – Specifies a color as a background. This option is available only when Background option is set to Solid color.
Load background – Specifies an image to use as a background. This option is available only when Background Image option is selected.
Mapping – Specifies the mapping method for the image - spherical or screen. This option is available only when Background Image is selected.
Rotation – Specifies a rotation angle in degrees for the background image. This option is available only when Background Image is selected.
Intensity – Specifies the intensity for the background image/color.
Use for refraction/mirror reflection – When enabled, the background override is used for both refraction and perfect (glossiness=1) reflection rays.
Advanced
Ambient light – Specifies a multiplier for the ambient light.
Lights tree – When enabled uses the Light tree method to trace the lights rays. You can further set the number of samples.
Environment importance sampling – Enables the environment importance sampling. This option aims to reduce the sampling noise on objects that are lit by the environment or have glossy reflections that see the environment. In most situations it is better to have Environment Importance Sampling enabled. You might want to disable this option only when using a solid color for the environment. This option is available only when Environment mode is set to Texture.
width5%
width30%
Lights List
In the lights list are listed all lights and their properties imported with a .vrscene file.
UI Text Box
typeinfo
Lights that have [G] in front of their name are grouped and share properties. Changing any value will be instanced in all the grouped lights. You can ungroup lights by clicking on the checkbox in front of "Grouped with ## other lights"
Expand
titleClick here for UI...
Div
classUIImage
UI Text Box
typeinfo
Lights will be automatically grouped/instanced if they share similar properties. This functionality will be available if the Display controls for all lights is disabled in the UI section of the Preferences dialogue.
Expand
titleClick here for Preferences UI...
Div
classUIImage
width65%
Compact – Displays only On/Off, color and intensity parameters for lights in the lights' list.
Basic – Displays common parameters for lights in the lights list.
Advanced – Displays all available parameters for lights in the lights list.
Ungroup selected lights – Ungroups selected lights in the scene which are part of a light group (have matching and identical properties) and makes them unique.
Enable All – Turns on all lights in the list.
Disable All – Turns off all lights in the list.
Expand All – Expands collapsed lights in the list.
Fold All – Collapses all lights in the list.
width5%
width30%
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
CardTooltipClick to open the V-Ray Sun page.
CardPageLinkSun Light
Sun Light
Click for detailed information about V-Ray Sun and its parameters.
Textboxcard
CardTooltipClick to open the V-Ray Sphere Light page.
CardPageLinkSphere Light
Sphere Light
Click for detailed information about V-Ray Sphere light and its parameters.
Textboxcard
CardTooltipClick to open the V-Ray Rect Light page.
CardPageLinkRect Light
Rect Light
Click for detailed information about V-Ray Rectangle(Plane) light and its parameters.
Textboxcard
CardTooltipClick to open the V-Ray IES Light page.
CardPageLinkIES Light
IES Light
Click for detailed information about V-Ray IES light and its parameters.
Textboxcard
CardTooltipClick to open the Max Point Light page.
CardPageLinkMax Point Light
Max Point Light
Click for detailed information about Point(Omni) light from 3Ds Max and its parameters.
Textboxcard
CardTooltipClick to open the Max Spot Light page.
CardPageLinkMax Spot Light
Max Spot Light
Click for detailed information about Spot light from 3Ds Max and its parameters.
Textboxcard
CardTooltipClick to open the Max Direct Light page.
CardPageLinkMax Direct Light
Max Direct Light
Click for detailed information about Direct light from 3Ds Max and its parameters.
Textboxcard
CardTooltipClick to open the Point Light page.
CardPageLinkPoint Light
Point Light
Click for detailed information about Point(Omni) light and its parameters.
Textboxcard
CardTooltipClick to open the Spot Light page.
CardPageLinkSpot Light
Spot Light
Click for detailed information about Spot light and its parameters.
Textboxcard
CardTooltipClick to open the Direct Light page.
CardPageLinkDirect Light
Direct Light
Click for detailed information about Direct light and its parameters.
