The Multipliers rollout is part of the Generic material's parameters.
Multipliers
width60%
Mode – Specifies how textures and colors will be blended by the multipliers.
Multiply – The texture is blended with a black color.
Blend Amount – The user-specified color is used for blending
Color – Controls the intensity of the Diffuse color.
Reflection Color – Controls the intensity of the reflection color.
Reflection Glossiness – Controls the intensity of the reflection sharpness.
Refraction Color – Controls the intensity of the refraction color.
IOR – Controls the intensity of the Index of Refraction value when calculating refraction.
Refraction Glossiness – Controls the intensity of the refraction sharpness.
Opacity – Controls the intensity of the overall material Opacity.
width5%
width35%
Example: Blending Colors
The following example shows how Blend Amount mode is used together with the Color multiplier.
width25%
width50%
Before after
afterLabel1.0
beforeLabel0.0
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
width25%
width30%
UI Text Box
sizemedium
Previous:
Generic Bump and Normal Mapping
width40%
width30%
UI Text Box
sizemedium
Previous:
Generic Override Control
