The New V-Ray Frame Buffer (VFB) is a second-generation V-Ray virtual frame buffer.
The New VFB is much more than a render image holder window, with Light Mix capabilities for modifying the project lighting after rendering and Layer Compositing for a higher level of post-processing adjustments.
Image preview: Loads render elements channels via a dropdown list; Works with display corrections; Loads various 8bit and 32bit file formats, including V-Ray resumable files; Image comparison between 2 or 4 renders;
Image management: Keeps the rendered image in full 32-bit floating-point format; Stores history of rendered images with their post rendering corrections; Saves corrected output to various image formats;
Image editing and post-processing: Add Color Corrections to rendered image and its elements; Layer Compositing for anything from a simple Back to Beauty workflow or advanced compositing; LightMix adjustment of the project lighting after rendering the image;
Project editing: Modifies actual lights values by transferring updated intensity and color from LightMix mode;
Render management: Denoiser control; Region rendering control and test resolution; Allows you to choose the order in which the buckets are rendered.
Collaboration: Shares images with other Chaos users in Chaos Cloud Rendering.
UI Text Box
type
note
VFB Cloud Collaboration is a new feature available only in V-Ray 6 for Revit.
To learn how to work with the New VFB, check the Courseware section.
