Section |
||Revit Ribbon|| > V-Ray tab > Render panel > Show / Hide Frame Buffer |
VFB Menu
The V-Ray Frame Buffer menu holds the main frame buffer commands. Some of the options are also available in the VFB toolbar for quick access.
Section | |||||||||||||||
Section | |||||||||||||||||||||||||
Layers
The New V-Ray Frame Buffer includes a suite of color corrections and tools for adjusting the image. The tools are added as layers and displayed in a layer tree. Enable or disable a particular tool using the visibility icon () to the left of its name. The icon indicates that a layer is disabled.
VFB Shortcuts
These shortcuts navigate through the VFB image. Please note that the VFB window must have the current focus for the shortcuts to have effect:
Log
The Log panel provides messages about the render process. Verbosity control is available and you can filter the type of messages shown in the Log: All, Error Only, Error & Warnings, or Error, Warnings & info. Additional options are available when you click on the Open options button:
Show progress – Shows a completion percent of each task (e.g. building Light Cache).
Wrap – Wraps longer lines in order to avoid horizontal scroll.
Undock – Docks/undocks the Log tab.
Note that the V-Ray Log is also accessible via the Show log button.
The Log tab can be detached and used as a separate window or docked elsewhere.
UI Text Box | ||
Ctr+F opens a search field at the bottom of the Log tab. |
VFB Shortcuts
Mouse | Description |
Mouse wheel | Zoom in/Zoom out |
Double-click left button | Zoom to 100% |
Middle button dragging | Pan (hand tool) |
Ctrl+Shift+Left click | Zoom in the rendered image |
Ctrl+Shift+Right click | Zoom out the rendered image |
Keyboard | Description |
Global | |
H | Show/hide history |
P | Show/hide only layers tree |
Ctrl+L | Show/hide whole right panel |
F11 | Toggle full screen |
S | Show/hide VFB settings |
History/Render View | |
E | Enable history A/B/C/D compare mode |
Q | Enable history A/B horizontal compare mode |
W | Enable history A/B vertical compare mode |
N | Edit a note in VFB History panel |
1-9 | Load the respective image from the new VFB history |
Layers/Property Panel | |
Ctrl+Y | Redo various actions related to layers such as create, delete, reorder or modify a layer. |
Ctrl+Z | Undo various actions related to layers such as create, delete, reorder or modify a layer. |
Layers | |
Del | Delete layer |
Message Log | |
Esc | Close search |
Ctrl+F | Activate the Search field in Log tab |
Return | Find next |
Shift+Return | Find previous |
Render View | |
Esc | Abort render |
Ctrl+C | Copy the VFB image to the Windows clipboard; the image is copied exactly as it appears on the screen (meaning sRGB/LUT/OCIO etc. corrections are applied). The full resolution image is copied to the clipboard, even if the VFB view is zoomed in/out. |
Ctrl+O | Load image |
L | Lock the mouse pointer coordinates and display information for the selected pixel, i.e. activate the Lock pixel info coordinates button. |
Arrow keys | Pan image |
left, up, right, down |
A |
Switch to Alpha channel | |
B | View Blue channel |
G | View Green channel |
R | View Red channel |
Page Down | View next channel |
Page Up | View previous channel |
* | Zoom to 100% |
+ / = | Zoom in |
-/_ | Zoom out |
F | Fit region or whole image in the VFB |
Render Region
Use Render Region in both Interactive and Production rendering modes to isolate only part of the frame for rendering.
