width65%
The Proportion Guide layer allows for a number of composition guides to be overlaid on the image. The
The available guides presets are Rule of Thirds, Diagonals, Golden Ratio, and Center Cross, and Custom Grid.
Rule of Thirds – Overlays the Rule of Thirds guidelines.
Diagonals – Overlays diagonal guidelines.
Golden Ratio – Overlays the Golden Ratio guidelines
Center Cross – Overlays a center cross guideline.
Custom Grid – Overlays custom grid guidelines. You can specify whereas Custom Grid allows specifying up to 10 custom columns and rows of the grid.
For all the guides there is a Line Width option, which can be controlled via a slider or spinners, as well as a Color Swatch to control the color of the lines.
For the Custom Grid Rows guides, there are Rows and Columns options to control the rows/columns of the grid.
width5%
width30%
