width50%
The V-Ray Frame Buffer offers options to configure the Render View, Render Region, History and Layers options. The settings mainly control visibility, location of stored renders and presets, amount of disk space to use and navigating within the VFB.
width5%
width45%
Image RemovedImage Added
Buttons
width60%
Save and close – Saves parameters configuration and closes the VFB Settings dialog.
Close – Closes the VFB Settings dialog without saving the changes.
width5%
width35%
