- The ZIP installation allows for setting a custom environment when starting each Houdini instance. In contrast, running the regular installation multiple times overwrites the V-Ray environment variables.
- The ZIP installation can be used to run V-Ray for Houdini and V-Ray Standalone from an arbitrary location or even a network drive. That way, multiple users can start Houdini along with V-Ray for Houdini using just a script that sets up the environment variables without the need to run local installations.
- Upgrading a ZIP installation is a lot easier too, as you don't need to run the installer on every user's computer.
- The ZIP installation allows for quickly switching between different V-Ray versions without reinstalling it.
