Code Block | ||||
{ "env": [ { "INSTALL_ROOT" : "C:/Program Files/Chaos Group/V-Ray/Houdini 19.05.383403" }, { "VRAY_APPSDK" : "${INSTALL_ROOT}/appsdk" }, { "VRAY_SDK" : "${INSTALL_ROOT}/appsdk" }, { "VRAY_OSL_PATH" : "${INSTALL_ROOT}/appsdk/bin" }, { "VRAY_UI_DS_PATH" : "${INSTALL_ROOT}/ui" }, { "VFH_HOME" : "${INSTALL_ROOT}/vfh_home" }, { "PATH" : [ "${HFS}/bin", "${VRAY_APPSDK}/bin", "${VFH_HOME}/bin" ]}, { "VRAY_FOR_HOUDINI_APPSDK_BIN" : "${VRAY_APPSDK}/bin" }, { "QT_PLUGIN_PATH" : "${HFS}/bin/Qt_plugins" }, { "QT_QPA_PLATFORM_PLUGIN_PATH" : "${HFS}/bin/Qt_plugins/platforms" }, { "VFH_DSO_PATH" : [ { "houdini_version < '19.0'": "${VFH_HOME}/dso_py3" }, { "houdini_version == '19.0' and houdini_python == 'python2'": "${VFH_HOME}/dso_py2" }, { "houdini_version == '19.0' and houdini_python == 'python3'": "${VFH_HOME}/dso_py3" } }, { "PYTHONPATH" : [ { "method": "append", "houdini_version == '19.5' and houdini_python == 'python2python3.7'": "${VRAYVFH_APPSDKHOME}/python27dso_py37" }, { "method": "append", "houdini_version == '19.5' and houdini_python == 'python3.9'": "${VRAYVFH_APPSDKHOME}/python37dso_py39" } ]}, { "VFU_PLUGINS" "PYTHONPATH" : [ { "method": "append", "value": "${VFHVRAY_DSO_PATHAPPSDK}/usd_plugins/hdVRay/pluginspython" } ]}, { "VFH_ASSET_PATH" : "C:/Users/USER/Documents/V-Ray Material Library/[MTLLIB_DOWNLOAD_DIR]/assets" }, { "HOUDINI_DSO_PATH" : "${VFH_DSO_PATH}" }, { "HOUDINI_GALLERY_PATH": [ { "method": "append", "value": "${VFH_HOME}/gallery" } ]} ], "path" : [ "${VFH_HOME}" ] } |
Windows
To deploy V-Ray using the ZIP archive instead of the installer, follow these steps:
For macOS: Note that the "packages" folder resides in Applications > Houdini > Houdini 18##.5#.### > Frameworks > Houdini.framework > Versions > 18##.5 > # > Resources > packages > ...
For detailed information on how to run V-Ray for Houdini, see the QuickStart Guides Introduction tutorial.
