width40%
Multiexcerpt include
MultiExcerptNameWhat is Chaos Cosmos
PageWithExcerptCOSMOS:Chaos Cosmos
width5%
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/75f2deJ_eUw" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
||Revit Ribbon|| > V-Ray tab > Assets panel > Chaos Cosmos
Image RemovedImage Added
Installation
MultiExcerptNameInstalling Chaos Cosmos
PageWithExcerptCOSMOS:Installing and Using Chaos Cosmos Browser
width50%
To start using the Chaos Cosmos Browser, you have to sign in. Press the Sign in button button at the top-right corner and enter your Chaos credentials in the newly opened browser tab.
width5%
width45%
width60%
Then, you can use the buttons at the top or use the search tab to find assets.
You can additionally choose between different categories and filters for date, popularity, color, and space. The option to Show downloaded only is also available.
The Navigation Bar, which is available on mouse hover on the browser's top frame, eases your navigation through the Chaos Cosmos pages. Note that when the page is reloaded, the navigation history is lost.
width5%
width35%
Image Modified
Once you choose an asset, you have to download it. Hover over it and click on the blue icon at the lower-right corner. Another way to download an asset is to click on it. This reveals additional information. You can see the category/space/color of the asset and other additional information.
width45%
Image Removed
width10%
width45%
Image Removed
Once the download is complete, a pop-up window will state that the asset is downloaded successfully. Use the Import button to bring the asset into the host platform.
Note that downloaded assets can be reused across different host platforms. They are saved locally at the following directory: C:\Users\[User]\Documents\Chaos Cosmos\Packages.
width45%
Image Removed
width10%
width45%
Image Removed
Placement
Cosmos objects appear as native Revit families containing a lightweight geometric representation of the object. Depending on the object type itself, those families are either host-based or freestanding.
UI Text Box
typenote
When a Cosmos asset is being imported during V-Ray Interactive rendering, the rendering is paused for the time of the import.
Modifications
width60%
In V-Ray, the Cosmos objects appear under the Appearance Manager > Families tab > Cosmos tab as part of the following categories: Entourage, Fixtures, Furniture, Lighting, Planting.
You can modify the Cosmos assets from within the Cosmos tab.
Scale – Scales the Cosmos asset.
Rotation – Rotates the Cosmos asset around its vertical axis.
Randomize/Seed – Defines scale and rotation range (min/max) for the selected items to be randomized. Use the Refresh (Image Removed) button on the right to choose between random combinations. Use the Navigation history arrows (Image Removed) to switch back and forth between random combinations.
Similar to proxies workflow, the replacement of native Revit families with Cosmos objects is supported. For more information, refer to the Families tab page.
width5%
width35%
Image Removed
HDRIs
width60%
When you download and import an HDRI, the light automatically changes to a Dome light, and the HDRI is assigned to it. You can see the preview of the HDRI in the V-Ray Lights window. For more information, refer to the V-Ray Dome Light page.
width5%
width35%
Image Removed
Updates
width60%
When Chaos Cosmos assets are missing and need to be downloaded, the Appearance Manager toolbar icon appears with a warning dot indicator.
The same indicator appears on the Families tab and in the Search field, when opening the Appearance Manager. When you click on the Image Removed indicator in the Search field, it filters and displays only the missing assets that need to be downloaded. In such case, the regular filter and search cannot be used and are disabled.
The Image Removed download button starts downloading the missing asset. It works on both single and multiple selection. When downloading is triggered, a progress bar and percentage appear next to each item.
width5%
width35%
 Image Removed
Fancy Bullets
  • Revit models containing Chaos Cosmos assets can be rendered in V-Ray Vision.
  • Revit models containing Chaos Cosmos assets can be rendered in Chaos Cloud.
  • Revit models containing Chaos Cosmos assets can be exported as .vrscene files.
  • Chaos Cosmos assets can be used with LightMix.
  • At render time, Cosmos objects work as V-Ray proxies. For more information, refer to the Proxy Mesh page.
  • With V-Ray 5, update 1, users can share the same network folder to their downloaded Cosmos Assets. Assets downloaded by one user, show as downloaded to all users. Find more information at Configuring the Asset Download Directory.
