This page provides information on the Coat Specular Render Element.
Section | |||||
Section | |||||||||||||||
Common Use
The Coat Specular RE can be used to enhance the highlights of the materials' coat. This is done by increasing the render element's contrast and applying it to the composition inside the VFB with an Add blend mode. In this example, a Cryptomatte mask is used to isolate the apples and they are edited in compositing.
Before after | ||||||||||
