Align | ||
Active Bodies collision
Complete control over collisions between Active Bodies using the Bullet solver. Easily create effects such as colliding ice cubes in liquid, floating ocean debris or objects washed away in floods.
Color Absorption
A whole new level of volume rendering effects using Colored Absorption. Achieve more control over smoke shading—change the light’s color as it travels through smoke.
Massive Wave Force
Build highly realistic ocean simulations. Create real-world ocean waves, using the Massive Wave Force feature.
Extended motion blur support on V-Ray GPU
Leverage GPU power to add motion blur to splashes and bubble mode in the Particle Shader.
Faster rendering and simulations
Take advantage of various speed gains on simulation, rendering and previews.
Property Lister window
Quickly access and change the Phoenix properties of each object in your scene—all in one place.
Autodesk Maya 2022 support
Phoenix is now compatible with the latest Autodesk releases.
With Phoenix FD 4.40 we added support for Maya 2022.
We implemented mutual collisions between Active Bodies so now you can create complex rigid body dynamics with Phoenix. In order to aid scenes with many interacting objects, we added a new Property Lister window, allowing you quick access to the per-node properties of the scene nodes.
Simulations of large scale stormy oceans or tunnel waves are now possible with the new Massive Wave Force.
A new colored absorption option allows for more interesting volume rendering effects, and can also be mapped via a texture. We added support for motion blur of Bubbles and Splashes in V-Ray GPU (requires a latest V-Ray 5).
The Phoenix standalone previewer can now be fully controlled via the command line, allowing you to change options and save image sequences of cache files in all different preview modes.
In this version of Phoenix, we multithreaded all remaining parts of the simulation, and also sped up the simulation, previews and rendering significantly.
We improved our shelf presets, added more options to the cache converter tool, and as always, fixed many issues.
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
Status | ||||||
Status | ||||
