Section | ||||||||||||||||||
Installing Pdplayer
The Pdplayer installer is pretty straightforward and easy to follow and can be downloaded from the Pdplayer Downloads section of the Chaos Group website. For Linux and Mac OS, the application shortcuts are available directly from the downloaded packets so they can be copied/organized under your Applications folder. If you would like a step-by-step guide, please check out the Installing Pdplayer page.
Licensing Pdplayer
Once Pdplayer is installed you will want to make sure that your license is properly configured. The Set Up Your Pdplayer License page includes everything you need to get Pdplayer licensed and running properly.
