The settings for geometry, materials, lights, etc. that V-Ray provides for working with Solaris LOP nodes appear as tabs in the ||stage|| network and are basically the same settings as those in V-Ray’s geometry, material, light, etc. nodes.
UI Text Box | ||
Please note that the V-Ray Hydra delegate is activated for V-Ray 5 builds for Houdini versions greater than 18.5.462*, on Windows and Linux only. OSX support is coming at a later stage. * If possible, please use the latest Houdini production build. |
Check the following links to learn more about how V-Ray and Solaris work together:
