V-Ray Environment Fog is not implemented yet.V-Ray Aerial Perspective is not implemented yet.
V-Ray Clipper is not implemented.
V-Ray Fur is not implemented
V-Ray Plane is not implemented
V-Ray Proxy import is not available due to a Solaris limitation
V-Ray VRScene import is not available due to a Solaris limitation
Known Issues
Fancy Bullets
type
circle
Using USD PrimVars for shading has no effect
Crash with V-Ray Color to Mono VOP
Updating Displacement materials will occasionally require a delegate restart
V-Ray materials will fail at automatically generating a Preview Surface Shader (Material Library LOP). The problem does not occur with 18.5.596 and above.
The V-Ray Hydra delegate will occasionally require a viewport pan/zoom to force an update
