V-Ray Render Settings are located in the V-Ray (Beta) tab of the Render Settings LOP. The settings are similar to those in the V-Ray Renderer ROP. The settings become available when you create a Render Settings LOP from ||stage|| > Rendering > Render Settings.
Some of the settings are also available in Houdini's Display Options toolbar.
Creating and Setting Attributes
The parameters that correspond to a USD attribute have a pop-up menu that controls how the LOP node authors the attribute.
Section | |||||||||||||||
V-Ray Tabs
Section | ||||||||||||||||||
Viewport Settings
The Viewport Settings can be accessed in the Display Options toolbar, or from the Display Options: Solaris window (press D or click the button).
The Show Denoised Result toggle denoises the render in the viewport. Note that a V-Ray Denoiser render element must be present and enabled for this toggle to work.
The Headlight Creation toggle creates headlight if no lights are present in the scene.
