To initiate the download process of V-Ray Material Library, run the mtllib tool located in:
C:\Program Files\AutodeskChaos Group\Maya20XX for x64\vray\bin\ (for Windows users); also available from the Start menu.
/usr/autodesk/maya20XXChaosGroup/V-Ray/Maya20XX-64/vray/bin/ (for Linux users)
/Applications/ChaosGroup/AutodeskV-Ray/maya20XXMaya20XX/vray/binVRay.app/Contents/MacOS(for macOS users)
When working with installation from .zip or portable installation, the mtllib file resides in your archived folder:
Win: unpack_zip_folder\maya_vray\bin\mtllib.exe
Linux: unpack_zip_folder/maya_vray/bin/mtllib.bin
macOS: unpack_zip_folder/maya_vray/bin/mtllib.bin
The default download directory for Windows users is C:\Users\USERNAME\Documents\V-Ray Material Library or /home/USERNAME/Documents/V-Ray Material Library on Linux and macOS. If you need to change it, use the following command line:
Code Block |
set VRAY_MTLIB_DOWNLOAD_DIR="C:\path\to\mtllib" |
For Linux and macOS users the commands for changing the default material library location are the same.
