CSS Stylesheet
.wiki-content .confluence-embedded-file-wrapper.confluence-embedded-manual-size {
    vertical-align: text-bottom;
This page offers information about the Move, Rotate, and Scale transform dialog menus in Chaos Vantage.
The Transforms dialog menus allow finer control over the position, rotation, and scale of the selected object. The dialog menus are accessible with a right-click on the Move(Vantage_TopToobar_MoveImage Modified), Rotate(Vantage_TopToobar_Rotate.pngImage Modified), and Scale(Vantage_TopToobar_Scale.pngImage Modified) buttons respectively in the top toolbar.
UI Text Box
typeinfo
Transform values are reset to 0 when in Local Space.
UI Text Box
typeinfo
Value boxes have blue outline when none or multiple objects are selected.
Translate type-in menu
width65%
X – Displays and specifies the selected object's position on the X axis.
Y – Displays and specifies the selected object's position on the Y axis.
Z – Displays and specifies the selected object's position on the Z axis.
width5%
width30%
Vantage_TranslateDialogueMenu.pngImage Modified
Rotate type-in menu
width65%
X  Displays and specifies the selected object's rotation on the X axis.
Y – Displays and specifies the selected object's rotation on the Y axis.
Z – Displays and specifies the selected object's rotation on the Z axis.
width5%
width30%
Vantage_RotateDialogueMenu.pngImage Modified
Scale type-in menu
width65%
X  Displays and specifies the selected object's scale on the X axis.
Y – Displays and specifies the selected object's scale on the Y axis.
Z – Displays and specifies the selected object's scale on the Z axis.
width5%
width30%
Vantage_ScaleDialogueMenu.pngImage Modified
