This page collects various useful utilities like the V-Ray Fur Styler, the mudbox2vrmesh, the vdenoise for Nuke and other tools related to V-Ray, which are not part of the official V-Ray installations.
Floatingpagetoc
VRMat migration utility tool
This command line tool allows batch migration of outdated .vismat or .vrmat files.
By default each file is updated to a version corresponding with V-Ray 5.1. This output version can be specified to accommodate for earlier V-Ray versions as well.
Note that legacy .vismat files that are not xml-based will not be migrated. If the contents of a .vismat file are not readable when opened with a text editor, it means the file cannot be migrated.
Usage:
vrmatmigrate [-h] [-v version] [-ow] [-gh] <paths>...
Command line options:
-h : Displays the tool's help info and a version lookup table
-v version : Upgrade the file(s) up to the specified version instead of the latest
-gh : Generates the color/float texture handler plugins
-ow : Overwrites the input file on save, instead of creating a copy with appended "_mig" suffix
-s : Specifies to search the subdirectories if the input path(s) are directories
<paths>... : One or more paths to files or directories to search for vismat/vrmat/vropt files
Example:
vrmatmigrate -ow -s "C:\%UserProfile%\Desktop\legacy_vismat_mtls"
Download version 1.0 (March 8th, 2021)
Windows:
macOS:
VRayFur styler
This modifier allows you to paint the initial and bend directions for VRayFur objects so that you can sort of "style" the appearance of VRayFur.
BY DOWNLOADING THIS CONTENT YOU AGREE TO BE BOUND BY THE TERMS OF THE EULA ATTACHED
Download for Nuke 8-12.2 13 for Windows and Linux: vdenoise_nuke.zip
For more information on how to use the plugin, visit the V-Ray Denoiser | VRayDenoiser page.
Download for Nuke 11.0-12.2 13 for Windows and Linux: lenseffects_nuke.zip
maketx 1.4.12
A 64-bit recompile of the maketx tool from the OpenImageIO library. Can be used to convert common texture formats to tiled .tx or .exr files for use with V-Ray.
