Hairs per Face – Specifies the number of fur strands per triangular face of the source object when Distribution is set to Per Face. Every triangle generates the specified number of fur strands.
Hairs per Unit Area – Specifies the number of strands per squared scene unit when Distribution is set to Per Area. For example, if the the system units are in meters, this parameter specifies the desired number of strands per square meter; if the system units are centimeters, it specifies the number of strands per square centimeter and so on. Every triangle face has at least one strand.
Length – The length of the fur strands. See the Length example below for more information.
Thickness – The thickness of the strands. See the Thickness example below for more information.
Gravity – Controls the force that pulls fur strands down along the Z-direction. See the Gravity example below for more information.
Gravity Vector – Specifies the gravity direction using vectors.
Bend – Controls the elasticity of the fur strands. When it is 0, the strands are hard and are all straight lines. Greater values cause the strands to bend (e.g. under the influence of gravity). See the Bend example below for more information.
Taper – Adds a taper to the individual strands of fur. Increasing this value will make the each strand thinner in its upper end and wider in its base. See the Taper example below for more information.
Fur Scale – Globallyincreasesthe fur.
width
5%
width
38%
Detail
width
57%
Hair Sides Knots – Knots – Controls the number of connect straight segments the fur strands are rendered in.
Level of detail – When enabled, V-Ray generates less fur geometry for parts of the scene which are far away from the camera. This is done by decreasing the density of the fur strands and increasing their thickness. The level of detail function helps for two things. One, it conserves memory by decreasing the detail where it is too far to be visible, and two - it helps to reduce animation flickering of very fine fur strands when they are far from the camera.
LOD Start Distance – The distance from the camera at which V-Ray starts implementing the level of detail adjustment. Up to this distance the fur is generated as specified by the user, after that V-Ray is decreasing the density and increasing the thickness of the strand by a factor of two for every n units of space specified by the LOD Rate parameter.
LOD Rate – The rate at which the detail adjustment is applied. Starting from the distance specified in the LOD Start Distance parameter V-Ray decreases the density and increases the thickness of the strands by a factor of two for every n units of space specified by the LOD Rate parameter.
Tessellation On – When enabled, V-Ray subdivides and smooths the fur strands before rendering. Strands closer to the camera are tessellated into finer segments so that they render smooth, while strands away from camera are simplified to reduce memory usage and speed up rendering.
Tessellation Edge Length – Specifies the desired edge length, in pixels, of each final segment of the fur strands when Tessellation On is enabled. Smaller values produce smoother strands but take more memory and are slower to render. Larger values are faster to render and take less RAM, but may cause the fur strands to appear jagged.
width
5%
width
38%
Image RemovedImage Added
Misc
width
57%
Flat Normals –
Ignore parent mesh displacement – When enabled, ignore the displacement and generate the fur based on the original undisplaced object, which by default, VRayFur will follow the displaced object's geometry.
