UI Text Box | ||||
UI Path: ||Hypershade|| > Create panel > Maya section > 3D Textures |
Particle SystemsSystem | particleSystem – Specifies the particle system that will be used. Note that only the first system in the set will be used. The rest will be ignored.
Use Particles in Local Space | localSpaceParticles – When enabled, the icon transformation can be used to move, scale, and rotate the particles. When disabled, the particles are directly represented in the world space as they are in the file.
