UI Text Box | ||
1) Please read over the license agreement. To continue with the installation process, click the I Agree button.
4) By default, V-Ray Swarm's Network Discovery is set up to auto-discover machines on the network. If the Use auto-discovery option is disabled, the custom configuration of the manually set Master Node Coordinator becomes available. This option is suitable if there is more than one subnet in the LAN or if you want to dedicate one or more machines to be Master NodesCoordinators. You may choose three machines as master nodescoordinators: one primary Master Node Coordinator (Master node Coordinator IP) and two alternate Master Nodescoordinators.
4) When the installation process is completed, click the Finish button.
