This page contains information for controlling the New V-Ray Frame Buffer through environment variables and MaxScript.
The V-Ray Frame Buffer can be controlled programmatically in two ways: the first is by using MaxScript commands and the second, by using various environment variables.
From MaxScript
vfbControl() MaxScript Function
The vfbControl() MaxScript function modifies the various aspects of the New VFB. These commands can be used in the MAXScript Listener or in an executable script. Commands follow this structure:
For example, to turn off the red channel in the New VFB, type:
Code Block |
vfbControl #red false |
Global VFB function | Description |
vfbControl() | Allows control over the various aspects of the New VFB. Type vfbControl() for a list of available parameters. |
vfbControl #show [true/false] | Opens (true) or Closes (false) the VFB window or returns its current display state if called without a value. |
vfbControl #getregion* | Returns an array with four integer elements, representing the pixel coordinates of the VFB render region (left, top, right, bottom). The left and top coordinates are included in the region, the right and bottom one are not. |
vfbControl #setregion* | Sets the VFB render region to the specified coordinates. Uses 4 integer values. For example, vfbControl #setregion 300 100 400 200 |
Anchor | ||||
Color Correction
Parameter | Description | Arguments | Examples |
#ocio | Enables the OCIO mode in the Display Correction layer or sets to None | Boolean | |
#icc | Enables the ICC mode in the Display Correction layer or sets to None | Boolean | |
#srgb | Enables the sRGB mode in the Display Correction layer or sets to None | Boolean | |
#ccociovt | Sets OCIO View Transform by number in the dropdown list | Integer | |
#ccocioics | Sets OCIO Input Colorspace by number in the dropdown list | Integer | |
#ccociodd | Sets OCIO Display Device by number in the dropdown list | Integer | |
#ocioinputcolorspace | Sets OCIO Input Colorspace by name | String | |
#ociodisplaydevice | Sets OCIO Display Device by name | String | |
#ocioviewtransform | Sets OCIO View Transform by name | String | |
#itemsociocs | Returns a list of all available OCIO Input Colorspace values | None | |
#itemsociodd | Returns a list of all available OCIO Display Device values | None | |
#itemsociovt | Returns a list of all available OCIO View Transform values | None | |
#itemsiccri | Returns a list of all available ICC Rendering Intent values | None | |
#cciccblackpoint | Enables/disables ICC black point compression | Boolean | |
#cciccrenderintent | 1 - Perceptual 2 - Relative colorimetric 3 - Saturation 4 - Absolute colorimetric | 1 | 2 | 3 | 4 | |
#loadocio | Specifies file for OCIO correction | String (filename) | |
#loadicc | Specifies file for ICC correction | String (filename) | |
#saveglobalccpreset | Save Global preset for the Corrections control panel to a specified .vccglb or .vfbl file | String (filename) | |
#loadglobalccpreset | Load Global preset for the Corrections control panel from a specified .vccglb or .vfbl file | String (filename) | |
#iccfile | Returns the filename (string) used in the corresponding Correction Control rollout | None | |
#ociosaveinfile #bkgrsaveinfile #lutsaveinfile | Enables the respective "save to image" checkboxes in the VFB. | Boolean | vfbcontrol #ociosaveinfile true |
#gamma22 | Enables Gamma 2.2 mode in the Display Correction layer or sets to None | Boolean |
Debug Shading
Parameter | Description | Value Options | Examples |
#debugshading | Enables/Disables Debug Shading | Boolean | vfbControl #debugshading true |
#debugshadinglockedselection | Switches from Isolate Selected to Isolate Locked Selection Debug Shading mode | Boolean | vfbControl #debugshadinglockedselection true |
#debugshadingmode | Sets Debug Shading mode with an integer: 0 - Isolate Selected/Isolate Locked Selection; 1 - Lighting; 2 - Ambient Occlusion; 3 - Wireframe; 4 - Normals; 5 - UVs; | Integer | vfbControl #debugshadingmode 1 |
History
#history | Enables/Disables History | Boolean | |
#showhistory | Shows/Hides History panel | Boolean | |
#historytemppath | Returns the path used for History Directory Sets path used for History Directory | None Path string | |
#historymaxsize | Returns the Size of VFB History in MB Sets the Size of VFB History in MB | None Integer | |
#historysave | Saves the current VFB image in history | None | |
#historyselect | Selects a History image based on index. | Integer | vfbControl #historyselect 2 |
#historyload #historyseta #historysetb #historyremove | Performs an operation on the History image that was selected with #historyselect on the previous line | None | vfbControl #historyselect 0 (required before next command) vfbControl #historyseta |
#historyclear | Deletes all images from history | None | |
#historycomment | Adds a comment to the History image that was selected with #historyselect on the previous line | String | vfbControl #historyselect 1 vfbControl #historycomment "Rendered with GI off" |
Layers
Instance of this object can be created with a call like vfbLayers=(vfbControl #getLayerMgr)[1]
Return Type | Name | Argument | Examples | Notes |
integer array | getAllLayerIDs | - | vfbLayers.getAllLayerIDs() | Get the IDs of all layers |
Layer | getLayer | Int layerID | layerA = vfbLayers.getLayer # | Get a layer object for the given layer ID |
string array | getCreatableLayerClasses | - | vfbLayers.getCreatableLayerClasses() | Return a list of the class names of layer classes that can be created |
Layer | createLayer | Int parentLayerID, String layerClass | vfbLayers.createLayer # "chaos.ref.re.colormask" | Create a new layer and add it as a child of the given parent |
Boolean | saveLayersToFile | Filename | vfbLayers.saveLayersToFile "C:\\temp\\layerstree.vfbl" | Save all layers to .vfbl file |
Boolean | loadLayersFromFile | Filename | vfbLayers.loadLayersFromFile "C:\\temp\\layerstree.vfbl" | Load layers from .vfbl file |
Boolean | bakeLayersToLUT | Filename | vfbLayers.bakeLayersToLUT "C:\\temp\\lutcc.cube" | Bake all layers (that can be baked) to a .cube file |
Void | deleteLayer | Layer | layerA = vfbLayers.getLayer # | Delete a layer. |
String | saveLayersToJSON | - | jsonlayers = vfbLayers.saveLayersToJSON() | Save all layers to a string containing the information in a JSON format |
Boolean | loadLayersFromJSON | JSON | vfbLayers.loadLayersFromJSON jsonlayers | Load layers from a string containing the information in a JSON format |
Boolean | transferLightMixToScene | - | vfbLayers.transferLightMixToScene() | Transfers LightMix corrections to the actual lights in the scene |
Lens Effects
#glareversion | Return the version of the lens effects | |
#glare | Turn lens effects On/Off | Boolean |
#glaresize | Sets Glare Size value | Float |
#glarebloom | Sets Bloom value | Float |
#glareintensity | Sets intensity value for the glare effect | Float |
#glarethreshold | Sets a Threshold value | Float |
#glarefilterrot | Sets Rotation of the final result effect | Float |
#glarecoldwarm | Turns on/off Cold/Warm | Boolean |
#glareblades | Enables/disables Blades | Boolean |
#glaresides | Sets the value of the Sides, i.e. the number of "rays" of the glare | Integer |
#glarebladesrot | Sets Glare Blades rotation | Float |
#glarestreakblur | Sets Streak Blur value | Float |
#glaresaturation | Sets Saturation value | Float |
#glarehwdacc | Turns on/off Hardware accelerate | Boolean |
#glareinteractive | Turns on/off Interactive | Boolean |
#glaregrating | Turns on/off Peripheral Grating | Boolean |
#glaregratingstrength | Sets Strength value of the blades effects | Float |
#glaregratingdensity | Sets Density of the grating effect in percent | Float |
#glaregratingzoom | Sets Zoom value | Float |
#glaregratingslope | Sets Slope value | Float |
#glaregratinglength | Sets Length for the of the grate lines | Float |
#glareocc | Turns on/off Occlusion | Boolean |
#glareoccsymmetric | Turns on/off Symetric | Boolean |
#glareoccpercent | Sets occlusion Percent value | Float |
#glareoccrot | Sets occlusion Rotation value | Float |
#glareoccarc | Sets occlusion Arc value | Float |
#glarescr | Turns on/off Lens Scratches | Boolean |
#glarescrsymmetric | Turns on/off Symmetric for scratches | Boolean |
#glarescrpattern | 0 - random 1 - stripe 2 - square 3 - hexagonal | 0 | 1 | 2 | 3 |
#glarescrstreaks | Sets lens scratches Streaks value | Integer |
#glarescrseed | Sets Seed value | Integer |
#glarescrdensity | Sets lens scratches Density value | Float |
#glarescrlength | Sets lens scratches Length value | Float |
#glarescrslopevar | Sets lens scratches Slope Variance value | Float |
#glarescrwidthvar | Sets lens scratches Width Variance value | Float |
#glarescrzoom | Sets lens scratches Zoom value | Float |
#glarescrrot | Sets lens scratches Rotation value | Float |
#glarescrstrength | Sets lens scratches Strength value | Float |
#glaredust | Turns on/off Lens Dust | Boolean |
#glaredustpattern | 0 - random | 0 | 1 | 2 |
#glaredustdensity | Sets lens dust Density value | Float |
#glaredustradvar | Sets lens dust Radius Variance value | Float |
#glaredustjitter | Sets lens dust Jitter value | Float |
#glaredustzoom | Sets lens dust Zoom value | Float |
#glaredustrot | Sets lens dust Rotation value | Float |
#glareduststrength | Sets lens dust Strength value | Float |
#glareobstacle | Enables/disables Use Obstacle image | Boolean |
#glareobstacleimage | Sets Path to the obstacle image | Path String |
#glareobstaclezoom | Sets Size of the obstacle image | Float |
#glareobstaclerot | Sets Rotation for the obstacle image | Float |
#glareobstaclestrength | Sets Strength value for the obstacle image | Float |
#glarefilter | Turns on/off Filter Image | Boolean |
#glarefilterimage | Specifies path to a filter kernel | Path String |
Stamps
#stamp | Enables/disables the stamp | Boolean | vfbControl #stamp true |
#stamphalign | Sets horizontal alignment for stamp | "left" | "center" | "right" | |
#stampvalign | Sets vertical alignment for stamp | "top" | "bottom" | |
#stamptext | Sets the text string to appear on the stamp | String | vfbControl #stamptext "Test rendering" |
Toolbar
#help | Displays options for the vfbControl command | None | |
#show | Opens (true) or closes (false) the VFB window or returns its current display state if called without a value | Boolean | |
#red | Enables/disables the corresponding VFB toolbar feature | Boolean | vfbControl #alpha true |
#trackmouse | Enables/disables the Track mouse while rendering feature | Boolean | |
#setcompareab | Enables/disables Compare horizontal and Compare vertical features | "h" | "hor" | "horizontal" | vfbControl #setcompareab "h" |
#loadimage | Loads the specified image in VFB | String (filename) | |
#saveimage | Saves the VFB current channel as an image | String (filename) | |
#saveallimage | Saves all VFB render channels to separate images or a single .vrimg file | String (filename) | |
#savemultiimage | Saves a multichannel .exr or .vrimg file with all VFB render channels inside | String (filename) | vfbcontrol #savemultiimage "D:\output\image.exr" |
#clearimage | Clears the VFB image | None | |
#duplicate | Duplicates the VFB | None | |
#hide | Hides the VFB | None | |
#getchannel | Returns the index of the currently selected render element channel. | None | |
#getchannelnames | Returns a list of the channels available in the current image | None | |
#setchannel | Selects the render element channel with an index | Integer | vfbControl #setchannel 0 |
#setregion | Sets the render region in pixels, or resets to entire image | Integers: left top right bottom "reset" | vfbControl #setregion 0 0 640 480 vfbControl #setregion "reset" |
#clamp | Enables/disables Force color clamping | Boolean | vfbControl #clamp true |
#viewclamp | Enables/disables View clamped colors | Boolean | |
#pixelaspect | Enables/disables Use pixel aspect | Boolean | |
#pos | Controls the position of the VFB window: | Integers: top left | vfbControl #pos 100 150 vfbControl #pos "reset" |
#testresolution | Enables/disables the Test resolution scale. | Boolean | vfbcontrol #testresolution true |
Sets the Test resolution value using an integer: 1- 10% 2 - 25% 3 - 50% 4 - 75% 5 - 110% 6 - 125% 7 - 150% | Integer: 1 | 2 | 3 | 4 | 5 | 6 | 7 | vfbcontrol #testresolution 1 | |
#testresolutionpreset | Returns current scale preset number. | None | vfbcontrol #testresolutionpreset |
Other MaxScript Functions
The following stand-alone functions complement the ones found in vfbControl():
vrayVFBGetRegionEnabled() | Returns whether region rendering in the New VFB is enabled (true) or disabled (false). |
vrayVFBGetRegion()* | Returns an array with four integer elements, representing the pixel coordinates of the VFB render region (left, top, right, bottom). The left and top coordinates are included in the region, the right and bottom one are not. |
vrayVFBSetRegionEnabled true|false | Turns on or off the VFB region render option. |
vrayVFBSetRegion left top right bottom* | Sets the VFB render region to the specified coordinates. |
vrayVFBGetNumChannels() | Returns the number of channels (render elements) in the New VFB. This will return 0 if the VFB is not initialized or does not store any data. |
vrayVFBGetChannelName i | Return the name of the i-th channel. Indexes start from 1. |
vrayVFBGetChannelType i | Returns the storage type of the i-th channel. Indexes start from 1. The return value specifies the type of data for each pixel in the given channel: |
vrayVFBGetChannelAlias i | Returns the alias for the i-th channel. Indexes start from 1. |
vrayVFBGetChannelBitmap i | Returns the contents of the specified channel as a 3ds Max bitmap. Indexes start from 1. This will return undefined if the channel index is not valid or the VFB does not contain any data. |
Anchor | ||||
Environment Variables
Some aspects of the New VFB can also be controlled with various environment variables:
Variable Name | Description |
VRAY_VFB_SRGB | Turn On (1) or Off (2) sRGB option of New VFB by default. |
VRAY_VFB_PIXEL_ASPECT | Turn On (1) or Off (2) Use pixel aspect option of New VFB by default. |
VRAY_VFB_GLOBAL_PRESET_FILE_USE | Enable (1) or Disable (0) automatic loading of a global .vccglb preset for the VFB. |
VRAY_VFB_GLOBAL_PRESET_FILE | Specify default .vccglb filename (string) to be used when loading automatic global preset. |
VRAY_VFB_ICC | Enable (1) or Disable (2) the ICC correction in VFB by default. |
VRAY_VFB_ICC_FILE | Specify default ICC correction file for New VFB. It will be automatically loaded when ICC is enabled. |
VRAY_VFB_OCIO | Enable (1) or Disable (2) the OCIO correction in New VFB by default. |
VRAY_VFB_OCIO_INPUT_COLORSPACE | Specify default input OCIO color space. A default OCIO configuration can be specified by the OCIO environment variable. |
VRAY_VFB_OCIO_DISPLAY_DEVICE | Specify default OCIO display device. A default OCIO configuration can be specified by the OCIO environment variable. |
VRAY_VFB_OCIO_VIEW_TRANSFORM | Specify default OCIO view transform. A default OCIO configuration can be specified by the OCIO environment variable. |
VRAY_VFB_LUT | Enable (1) or Disable (2) the LUT correction in New VFB by default. |
VRAY_VFB_LUT_FILE | Specify default LUT correction file for New VFB. It will be automatically loaded when LUT is enabled. |
VRAY_VFB_AFFECT_SWATCHES | Apply VFB corrections to swatches in the Material Editor: 0 - none 1 - OCIO only 2 - all corrections except sRGB 3 - all corrections including sRGB |
VRAY_VFB_ALWAYS_ON_TOP | Specify a ALWAYS ON TOP behavior: 0 - disabled 1 - force enable always on top 2 - force disable always on top |
