Basic Parameters
Section | |||||||||||||||
Anchor | ||||
Example: Enable Flakes
The Enable Flakes parameter allows the user to turn the Stochastic Flakes effect on and off. When on, flakes are scattered across the surface of the material. When off, the material renders with only the specified BRDF Type and Hilight Glossiness. In the example below, the BRDF Type is set to GGX. Click on the image to open the full-resolution.
Section | ||||||||||||||||||||||||||||||||||||||||||||
none | Panel |
Anchor | ||||
Example: Number of Flakes
Colored Flakes Parameters
Anchor | ||||
Example: Random Color Map
Advanced Parameters
Multiexcerpt include | ||||
Options
Preview Settings
References
The V-Ray Stochastic Flakes Material is based on the Chaos paper "A Practical Stochastic Algorithm for Rendering Mirror-Like Flakes" (PDF Download).
