CSS Stylesheet
.rwui_text_box {
margin:0px;
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Responsivegridmacro
VAlignmentstart
Columns3width1290px
Columns1width1540px
Columns2width1290px
This page provides information on the guide shows you how to set up Live Link feature from SketchUp in to Chaos Vantage. For more information about Live Link, see the Tools in SketchUp page.
Div
classRespColumnsHeader
width45%
The Live Link feature makes it possible to instantly see changes made in SketchUp without the need to export and import .vrscenes in Chaos Vantage.
width55%
Align
alignright
HTML
<iframe width="560" height="350315" src="https://www.youtube.com/embed/7fndXZOpDvY" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Live Link Setup
For Live Link to function properly, please follow the steps below:
I. Installation
UI Text Box
typenote
Live Link works only with V-Ray 5 for SketchUp, update 2 or later versions.
width50%
1. Download and install the latest official V-Ray for SketchUp build from the download button. Make sure you have appropriate licenses. If you experience problems, please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray for SketchUp
urlhttps://download.chaosgroup.com/?platform=56&product=47
width50%
2. Download the latest Chaos Vantage build from the download button. Make sure you have appropriate licenses. If you experience problems, please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage
urlhttps://download.chaosgroup.com/?platform=47&product=63
II. Initiation
After installation, Live Link can be initiated in one of the following 2 ways:
A. Start Chaos Vantage
width50%
 Use the Start Chaos Vantage in SketchUp. It can be accesses either from:
Fancy Bullets
typecircle
  • the Start Chaos Vantage button in the Chaos Vantage toolbar which is hidden by default but can be enabled from View > Toolbars > Chaos Vantage
  • the Start Chaos Vantage command accessible from Extensions > V-Ray > V-Ray Live Link
Using either of the two initializes a
live link
Live Link session between SketchUp and Chaos Vantage.
It automatically:
Fancy Bullets
typecircle
  • Starts Chaos Vantage if it is not already running;
  • Sends the scene to Chaos Vantage on 20701 port
    When clicked again, closes the Live Link connection
width5%
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/qhLWHdI4gq0?list=PLm2Irfq-UvZ3h2Sxw2FVd9qjOIpqHOLiG" title="Using Live Link from SketchUp to Chaos Vantage" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
width50%
Start a Custom Live Link session in SketchUp.
Expand
titleClick here to expand for manual Live Link setup
In Sketchup:
width100%
1. Open the Customize Live Link dialogue Specify address and port dialog by going to Extensions > V-Ray > V-Ray Live Link > Customize Live Link:
1.1 Specify the following:
Fancy Bullets
typecircle
  • Address – add your local machine as as server. Enter either localhost or 127.0.0.1
  • Port – specify a port range for which Chaos Vantage awaits incoming data. By default it is 20701
1.2 Close the Customize Live Link dialogue Specify address and port dialogby clicking the OK button.
In Chaos Vantage:
width50%
1. Open Chaos Vantage.
width5%
width45%
width60%
2. Open the Live Link menu and make sure Start Server is enabled (greyed out). If Start Server on Application Start is enabled, every time Chaos Vantage is launched in stand-by mode and waits for incoming data.
width5%
width35%
width60%
3. Setup Set up port range in Change Port... menu and make sure the range entered here matches the one previously set in SketchUp. Default is 20701.
width5%
width35%
Back In Sketchup:
width100%
Start Live link Link by going to Extensions > V-Ray > V-Ray Live Link > Start Custom Live Link.
width5%
width45%
III. Pause and Termination
width50%
Once a Live Link session is started, the scene is transferred to Chaos Vantage and a thick blue contour line appears around the viewport and the status message in the lower right changes to [LIVE LINK]
UI Text Box
typeinfo
The Pause when app loses focus option in the Preferences menu is ignored when in Live Link session.
To stop a Live Link session, either click again the Start Chaos Vantage button, Start Custom Live Link option, or open the VFB and stop the Interactive rendering.
width5%
width45%
Vantage_Hero
Supported Features
The following changes made in SketchUp are propagated through Live Link:
Fancy Bullets
typecircle
  • Editing, creating and deleting of:
    • Camera
    • Geometries
    • Lights
    • Materials
    • Textures
    • Environment
Excerpt IncludeLive Link SetupLive Link Setupnopaneltrue
