Responsivegridmacro
VAlignmentstart
Columns3width1000px
Columnsrepeat(2, 1fr)
ClassRespColumnsHeader
Columns2width1450px
CSS Stylesheet
.rwui_text_box {
margin:0px;
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Responsivegridmacro
VAlignmentstart
Columns3width1290px
Columns1width1540px
Columns2width1290px
This page provides information on the guide shows you how to set up Live Link feature from Rhino in to Chaos Vantage. For more information about Live Link, see the Tools in Rhino and Grasshopper page.
Div
classRespColumnsHeader
The Live Link feature makes it possible to instantly to instantly see changes made in Rhino without the need to export and import .vrscenes in Chaos Vantage.
Align
alignright
HTML
<iframe width="560" height="350" src="https://www.youtube.com/embed/p-ea0RytePs" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Live Link Setup
For Live Link to function properly, please follow the steps below:
I. Installation
UI Text Box
typenote
Live Link works only with V-Ray 5 for Rhino, update 2 or later versions.
width50%
1. Download and install the latest official V-Ray for Rhinobuild from the download button. Make sure you have appropriate licenses. If you experience problems, please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray for Rhino
urlhttps://download.chaosgroup.com/?platform=51&product=47
width50%
2. Download the latest Chaos Vantage build from the download button. Make sure you have appropriate licenses. If you experience problems, please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage
urlhttps://download.chaosgroup.com/?platform=47&product=63
II. Initiation
After installation, Live Link can be initiated in one of the following ways:
A. Chaos Vantage button
width50%
Use the Chaos Vantage button in Rhino. It can be accessed either from the Chaos Vantage button in the VRay Live Linking toolbar which is hidden by default but can be enabled from:
Fancy Bullets
typecircle
  • Tools > Toolbar Layout > VRayForRhino > VRay Live Linking
  • right click on Shelf > Show Toolbar > VRay Live Linking
or from the V-Ray menu > Rendering > Chaos Vantage.
Using either of the two initializes a live link Live Link session between Rhino and Chaos Vantage. It automatically:
In Chaos Vantage:
width50%
1. Open Chaos Vantage
Fancy Bullets
typecircle
  • Starts Chaos Vantage if it is not already running
  • Sends the scene to Chaos Vantage on 20701 port(default)
width5%
width45%
vrayVantage command
width5%
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/1uzNwWtyv9k?list=PLm2Irfq-UvZ3h2Sxw2FVd9qjOIpqHOLiG" title="Using Live Link from Rhino to Chaos Vantage" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
B. vrayVantage command
width50%
In Chaos Vantage:
1. Open Chaos Vantage.
2. Open the Live Link menu and make sure Start Server is enabled (greyed out). If Start Server on Application Start is enabled, every time Chaos Vantage is launched in stand-by mode and waits for incoming data.
width5%
width45%
width50%
3. Setup Set up port range in Change Port... menu and make sure the range entered here matches the one previously set SketchUpin Rhino. Default is 20701.
width5%
width45%
In Rhino:
width50%
1. Execute vrayVantage in the command line.
2. Specify the same IP and Port values that were set in Chaos Vantage. Defaults are IP: 127.0.0.1 and Port: 20701.
3. Hit Enter to execute the command and start the Live Link connection.
width5%
width45%
C. V-Ray Live Link component in Grasshopper
In Chaos Vantage:5%
width50%
In Chaos Vantage:
width50%
width
width45%
width5%
width45%
width50%
3. Setup port range in Change Port... menu. Default is 20701.
width5%
width45%
In Grasshopper:
width50%
1. Create a V-Ray Live Link component and plug the Scene output from a V-Ray Render component to the Scene input of the V-Ray Live Link component .
2. Specify the same Port value that was set in Chaos Vantage. Default is Port: 20701.
3. Right-click on On input > Set boolean > True to initiate a Live Link connection.
width5%
width45%
III. Pause and Termination
width50%
Once a Live Link session is started, the scene is transferred to Chaos Vantage and a thick blue contour line appears around the viewport and the status message in the lower right changes to [LIVE LINK].
UI Text Box
typeinfo
The Pause when app loses focus option in the Preferences menu is ignored when in Live Link session.
To stop a Live Link session either:
Fancy Bullets
typecircle
  • Click again the Chaos Vantage button in the VRay Live Linking toolbar.
  • Execute vrayVantage command again.
  • Right-click on On input > Set boolean > False in the V-Ray Live Link component in Grasshopper (if using V-Ray for Grasshopper)
  • Open the VFB and stop the Interactive rendering.
width5%
width45%
Vantage_Hero
Supported Features
The following changes made in Rhino are propagated through Live Link:
Fancy Bullets
typecircle
  • Editing, creating and deleting of:
    • Camera
    • Geometries
    • Lights
    • Materials
    • Textures
    • Environment
Excerpt IncludeLive Link SetupLive Link Setupnopaneltrue
