Floatingpagetoc
Responsivegridmacro
VAlignmentstart
Columns3width1000px
Columnsrepeat(2, 1fr)
ClassRespColumnsHeader
Columns2width1450px
CSS Stylesheet
.rwui_text_box {
margin:0px;
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Responsivegridmacro
VAlignmentstart
Columns3width1290px
Columns1width1540px
Columns2width1290px
This page provides information on the Live Link feature from Rhino in Chaos Vantage.
Div
classRespColumnsHeader
The Live Link feature makes it possible to instantly see changes made in Rhino without the need to export and import .vrscenes in Chaos Vantage.
Align
alignright
HTML
<iframe width="100%" height="350" src="https://www.youtube.com/embed/p-ea0RytePs" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Live Link Setup
For Live Link to function properly please follow the steps below:
Installation
UI Text Box
typenote
Live Link works only with V-Ray 5 for Rhino, update 2 or later versions.
width50%
1. Download and install latest official V-Ray 5 for Rhino, update 2 or laterbuilds from the download button. Make sure you have appropriate licenses. If you experience problems please contact Chaos Support using the  online form .
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload VRay 5 for Rhino
urlhttps://download.chaosgroup.com/?platform=51&product=47
width50%
2. Download latest Chaos Vantage build from the download button. Make sure you have appropriate licenses. If you experience problems please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage
urlhttps://download.chaosgroup.com/?platform=47&product=63
After installation Live Link can be initiated by either of 2 ways:
Chaos Vantage button
width50%
Use the Chaos Vantage button in Rhino. It can be accesses either from the Chaos Vantage button in the VRay Live Linking toolbar which is hidden by default but can be enabled from:
Fancy Bullets
typecircle
  • Tools > Toolbar Layout > VRayForRhino > VRay Live Linking
  • right click on Shelf > Show Toolbar > VRay Live Linking
Using either of the two will initialize a live link session between Rhino and Chaos Vantage.  It will automatically:
Fancy Bullets
typecircle
  • Start Chaos Vantage if it is not already running;
  • Send the scene to Chaos Vantage on 20701 port(default) ;
width5%
width45%
vrayVantage command
In Chaos Vantage
width50%
1. Open Chaos Vantage.
width5%
width45%
width50%
2. Open the Live Link menu and make sure Start Server is enabled (greyed out). If Start Server on Application Start is enabled every time Chaos Vantage is launched  in stand-by mode and wait for incoming data.
width5%
width45%
width50%
3. Setup port range in Change Port.. menu and make sure the range entered here matches the one previously set SketchUp. Default is 20701.
width5%
width45%
In Rhino
width50%
1. Execute vrayVantage in the command line.
2. Specify the same IP and Port values that were set in Chaos Vantage. Defaults are IP: 127.0.0.1 and Port: 20701.
3. Hit Enter to execute the command and start the Live Link connection.
width5%
width45%
V-Ray Live Link component in Grasshopper
In Chaos Vantage
width50%
width5%
width45%
width50%
width5%
width45%
width50%
3. Setup port range in Change Port.. menu. Default is 20701.
width5%
width45%
In Grasshopper
width50%
1. Create a V-Ray Live Link component and plug the Scene output from a V-Ray Render component to the Scene input of the V-Ray Live Link component .
2. Specify the same Port value that was set in Chaos Vantage. Default is Port: 20701.
3. Right-click on On input > Set boolean > True to initiate a Live Link connection.
width5%
width45%
width50%
Once a Live Link session is started the scene is transferred to Chaos Vantage, a thick blue contour line appears around the viewport and the status message in the lower right changes to [LIVE LINK]
UI Text Box
typeinfo
The Pause when app loses focus option in the Preferences menu will be ignored when in Live Link session.
To stop a Live Link session either:
Fancy Bullets
typecircle
  • Click again on the Chaos Vantage button in the VRay Live Linking toolbar.
  • Execute vrayVantage command again.
  • Right-click on On input > Set boolean > False in the V-Ray Live Link component in Grasshopper (if using V-Ray for Grasshopper)
  • Open the VFB and stop the IPRInteractive rendering.
width5%
width45%
Supported Features
The following changes made in Rhino will be propagated through Live Link:
Fancy Bullets
typecircle
  • Editing, creating and deleting of:
    • Camera
    • Geometries
    • Lights
    • Materials
    • Textures
Excerpt Include
Live Link
Live Link
nopaneltrue
