Timeline – Shows/Hides the timeline area user interface.
Layer Stack – Shows and hides the layer stack.
Information Bar – Shows/Hides the information bar.
Layer Properties – Shows/Hides the layer properties panel.
Preview Area TooltipPixel Info – When this option is selectedenabled, holding the mouse pointer over a pixel will bring out a tooltip containing the toolbar displays information about that pixelthe pixel that the mouse is currently hovering over. This includes X and Y coordinates, RGB color and HSV color values.
Mask – Shows/Hides the resolution mask in the preview area.
Grid – Shows/Hides the workspace grid.
Synchronize Display – Toggles the vertical synchronization. Prevents tearing but will have a performance hit.
Reset/Fit to Window – Resets the workspace pan to the default 0, 0 position and the zoom to 100%/ Fits all visible layers to the preview area performing pan and zoom at the same time.
Zoom In – Zooms in the workspace in steps (10%, 20%, 30%, 50%, 100%, 200%, 400%).
Zoom Out – Zooms out the workspace in steps (10%, 20%, 30%, 50%, 100%, 200%, 400%).
Resize Window to Fit – Resizes the Chaos Player window to fit all viewable layers.
Toggle Red Channel – Toggles the visibility of the composition’s red channel in grayscale.
Toggle Green Channel – Toggles the visibility of the composition’s green channel in grayscale.
Toggle Blue Channel – Toggles the visibility of the composition’s blue channel in grayscale.
Toggle Alpha Channel – Toggles the visibility of the composition’s alpha channel in grayscale.
Toggle Luma Channel – Toggles the visibility of the composition’s luma channel in grayscale.
Toggle Red Channel Mode – Toggles the visibility of the composition’s red channel in color.
Toggle Green Channel Mode – Toggles the visibility of the composition’s green channel in color.
Toggle Blue Channel Mode – Toggles the visibility of the composition’s blue channel in color.
