This page provides information on the Effects Panel in the Property Panel.
Page Contents
Table of Contents | ||
The Effects Panel is part of Pdplayer's Property Panel and allows you to apply Color Key to your Sequence or Video Layers. Pdplayer currently supports two Color Keys which will be The Color Key Property Panel allows you to apply color keys to your layers. Currently, two color keys are supported and applied on the fly.
HideElements | ||
Properties
UI Path: ||Property Panel|| > Effects > Color Key panel
Section |
