Build 2.00.22
Official release
Date - Jan 17, 2022Build 2.00.21 Apr 29 2022
UI Button | ||||||||||
New Features
- Added read support for tiled mip-mapped .tx and .tex TIFF files;
Modified features
- Implemented OpenGL rendering for faster playback;
- Added a --enable_cpu_render startup flag for CPU rendering mode;
- Moved the pixel sampling information to the main info bar;
- Added a startup shortcut link on Linux;
- Limited the layer stack's height to display only a reasonable number of layers;
- Playback is now automatically paused when rendering to file;
- The property panel can now be scrolled by mouse dragging;
- Now reading metadata from V-Ray Image .vrimg files;
- The default color correction mode is now Gain;
Bug fixes
- Fixed broken --attach command-line flag;
- Fixed wrong state of some toolbar icons;
- Removed wrong .dng file association on Windows;
- Fixed "Open Containing Folder" for layer not working;
Chaos Player
Official release
Date - Jan 17, 2022
Build 2.00.21
New Features
- Export to MP4 video files
- Added A/B wipe compare with up to 4 inputs
- Added HiDPI interface scaling
- Added support for OCIO v2 configurations
- Changed the interface color theme to neutral grey
- Added interface workspaces layouts
- Integrated the Chaos installer
- Improved floating-point precision handling
- Changed caching defaults for improved performance
- Improved Full-Screen workflow
- Extended toolbar for easier access to often used tools
- Premultipled Alpha is now the default alpha blending mode
- Removed the Premultiplied Mask alpha blending mode from the interface
