Floatingpagetoc
This page provides information about the Render animation with Chaos Vantage MAX script.
The Render animation with Chaos Vantage and Render animation with Chaos Vantage, using Vantage UI MAX script helps you to send and render your animated 3Ds Max scene to Chaos Vantage with a click of a button.
Installation
The installation of the tool comes with the installation of V-Ray 5 for 3ds Max, update 2 and later.
UI Path
To access the script,
go to ||Vantage toolbar|| > Render animation with Chaos Vantage ()If button is not visible press and hold the Render animation with Chaos Vantage, using Vantage UI ()button to open the drop-down menu.
Column | ||
width | 50% |
in 3ds Max go to ||Vantage toolbar|| > Render animation with Chaos
Vantage, usingVantage
UI(
)If button is not visible press and hold the Render animation with Chaos Vantage (
Section | |||||||||||||||
When clicking on the Render animation with Chaos Vantage () button, the following dialog appears:
When clicking on the Render animation with Chaos Vantage, using Vantage UI () button Next, the following dialog appears in Chaos Vantage:
Usage
Section | ||||||||||||||||||||||||
