For more information on how to work with the V-Ray Proxy, see the the V-Ray Proxy courseware page page.
Basic Parameters
Section | |||||||||||||||||||||||||
Advanced Overrides
Section | ||||||||||||||||||||||||||||||
Animation Parameters
Alembic Layers
Anchor | ||||
Example: Applying Visibility Overrides
There is no difference between applying Visibility Overrides to .vrmesh (V-Ray Proxy) files and .abc (Alembic) files. Visibility overrides are applied to objects in the hierarchy.
You can use asterisks as wildcards when inputting the names of the objects/ groups in the Rule. Pressing Enter confirms the input.
Example: Applying Shader Overrides
Anchor | ||||
Example: Applying Override to objects with similar names
Alembic
Layers
Point Cloud
VRayMesh file info
Material Assignment Overrides
Alembic proxy parameters
Point Cloud
VRayMesh file info
Code Block | ||||
<materialAssignmentRules> <patternRule> <pattern>VRayMtl1</pattern> <material>VRayMtl1@material</material> </patternRule> </materialAssignmentRules> |
The sample XML assigns the VRayMtl1 material to all vrmesh objects matching VRayMtl1 pattern, i.e. all objects whose material name is VRayMtl1.i.e. all objects whose material name is VRayMtl1.
Code Block | ||||
from vray.utils import *
appendSceneContent("C:/mtlAssignments/materials.vrscene") |
For this feature to work, you need to specify the path to the . vrscene containing the materials (procedural textures or paths to bitmaps). This only works with post-translate python script. The following example script specifies the path to the . vrscene file and should be copied into Render Settings > Common > MEL / Python callbacks > Post translate python script.
Code Block | ||||
Code Block | ||||
<patternRule>
<pattern>/pCube*</pattern>
<sceneMaterial>VRayMtl1@material</sceneMaterial>
</patternRule>
<patternRule>
</patternRule>
The sample XML assigns the VRayMtl material to all alembic objects matching the pattern pCube* , i.e. all objects whose name starts with pCube. It uses the new sceneMaterial tag.
UI Text Box | ||
The material assignment overrides is still an experimental feature and can change at any point! |
Example: Instancing V-Ray proxy with MASH
| note
Fancy Bullets | ||||||||||
