Responsivegridmacro
VAlignmentstart
Columns3width1000px
Columnsrepeat(2, 1fr)
ClassRespColumnsHeader
Columns2width1450px
CSS Stylesheet
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
div
classRespColumnsHeader
Official Release
Date - December 06, 2021
Align
alignright
HTML
<iframe width="100%" height="350" src="https://www.youtube.com/embed/bT7nw4VPnxk" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Responsivegridmacro
VAlignmentstart
Columns3width1000px
Gap20px
ClassRespColumns3
div
classRespColumns3
New Features
Cosmos materials
Fancy Bullets
  • Support for Cosmos materials
  • Remove unused cosmos materials option in the Material list
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Materials+tab
Batch rendering
Fancy Bullets
  • Support for batch rendering. Still image and Sequence jobs can be added to a render queue
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Menus#MenusTools+Menu#ToolsMenu-renderQueueRenderQueue
UX
Fancy Bullets
  • Import option in the File menu for easier importing of supported file formats
Supported formats
Fancy Bullets
  • Experimental support for opening and importing FBX, OBJ, 3DS, PLY, STL, TER, DAE, GLTF file formats
Modified
UX
Fancy Bullets
  • The Snapshot and Sequence dialogs are now united in a single Render dialog
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Menus#MenusTools+Menu#ToolsMenu-qualityRendersetup
  • Animation frame range setting in the Render dialog
  • Render time estimation in the Progress window
  • Non-zero default values for transform snapping. New defaults are:
    • Translate 10 scene units
    • Rotate 15 degrees
    • Scale 0.1
  • Object list improvements:
    • CTRL + A selects all objects, including children
    • SHIFT + Expand/Collapse applies to children too
    • DELETE key deletes the selected object
    • SHIFT + DELETE key deletes the selected object and its children
    • All selected items are expanded/collapsed with the item currently expanding/collapsing
Performance
Fancy Bullets
  • Optimized GPU memory usage:
    • Light Cache is now several times smaller
    • Unused textures are unloaded from the GPU
Fancy Bullets
  • Creation and updating of textures for lights
Fixes
Textures
Fancy Bullets
  • VRayMultiTexture and VRayTriplanar randomization options not working with scenes from V-Ray 5, update 2
Memory
Fancy Bullets
  • Crash after loading a new scene after a failed memory allocation
Multi GPU
Fancy Bullets
  • Line artifacts with multi GPU after opening the material browser
