 This page provides information about the AB Wipe frature.
width45%
A/B wipes are very useful when tech-checking animation output. It can be used during playback or for still images.
Use the grid left of the layer stack to set which layer is assigned the A, B, C or D letters.
Then enabling the  icon toggles the wipes on or off. For more information, see the video.
width5%
width50%
Image Removed
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/_xFHX64iAbk" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Options
width45%
You can wipe between two pictures vertically or horizontally. Additionally, comparison can be made between four images. Right click on the AB Wipe Compare button to see some context options.
A/B HorizontalSelect two images to wipe horizontally.
A/B Vertical – Select two images to wipe vertically.
A/B/C/D – Select four images to compare.
Gray/Green/Orange Wipe Bar – Select the wipe bar color.
width5%
width50%
