Section | |||||||||||||||||||||||||||||||||||||
UI Button | ||||
Example: Decal
Anchor | ||||
Example: Fade Angle
The Normal Angle is set to 40 degrees. The first image shows the decal effect without a Fade Angle. The second render has Fade Angle enabled and set to 120 degrees. Note how the effect is enclosed between the Normal and Fade Angles.
Anchor | ||||
Example: Decal Displacement
This example shows the effect of decal displacement.
Anchor | ||||
Example: Use Only Decal Displacement
This example shows the effect of decal displacement. Use Only Decal Displacement is turned on in the second image.
Fancy Bullets | ||
