This page provides a tutorial on creating Animated Clouds with Phoenix for 3ds Max.
UI Text Box | ||
This Advanced Level tutorial shows you how to create Animated Clouds using Phoenix. Note that creating a production quality shot may require some tweaks to lighting, materials and/or the Phoenix simulation. |
Section | |||||||||||||||||||||||||||
Units Setup
Scene Layout
Scene Setup
UI Text Box | ||||||||||||||||||||||||||||||||||||||||||||
This tutorial involves two simulators and a lot of steps. Here we focus on the Phoenix-related steps only. Feel free to use the camera and light settings in the provided sample scene.
Anatomy of the Animated Clouds
Comparison of Cumulus and Stratus Clouds
Section | |||||||||||||||||||||||||||||||||
Fire/Smoke Simulation for Cumulus
Output Settings
Cumulus Source Geometry Setup
Creating and Animating a Phoenix Fire/Smoke Source in the Scene
Section | |||||||||||||||||||||||||||||||||||||||||||||
Animate the PHXSource_Cumulus001 Outgoing Velocity
Initial Simulation
Switch to PCG Solver
Adding Phoenix Turbulence for Smoke Swirls
Set up Two More Sources for Cumulus
Adding Plain Force
Final Simulation for the Cumulus
Retime for the sources and textures
Resimulation for the Cumulus
Scene Interaction
Fire/Smoke Simulation for Stratus
Create a Geosphere Geometry
Adding a Fire/Smoke Source for Stratus
Scene Interaction
Smoke Dissipation
Improving Volumetric Shading
Border Fade for Stratus
Render Elements
V-Ray Frame Buffer
Relighting with LightMix
Phase Function
Phase Function comparison (front lighting)
Bonus step: back lighting condition
Phase Function comparison (back lighting)
