Responsivegridmacro
VAlignmentstart
Columns3width1000px
Columnsrepeat(2, 1fr)
ClassRespColumnsHeader
Columns2width1450px
CSS Stylesheet
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Div
classRespColumnsHeader
https://download.chaosgroup.com/?platform=47&product=63
Official Release
Date - December 16, 2021
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage, 1.6.1 Build
url
Align
alignright
Responsivegridmacro
VAlignmentstart
Columns3width1000px
Gap20px
ClassRespColumns3
Div
classRespColumns3
Modified
UX
Fancy Bullets
  • Place tool now locks the selected object's current orientation while SHIFT key is pressed
  • A sample HDR file is loaded when opening non-vrscene files
UI
Fancy Bullets
  • Added progress indication when importing FBX, OBJ, 3DS, PLY, STL, TER, DAE, GLTF file formats
Textures
Fancy Bullets
  • Better parity when using the VRayUVWRandomizer in V-Ray for Cinema4D
Non-vrscene files
Fancy Bullets
  • Default up direction (now Y) for OBJ and 3DS files
Fixes
Fancy Bullets
  • Animation rendering started with Vantage UI renders the same frame over and over
  • Animation synchronization bug in 3ds Max
.vantage file
Fancy Bullets
  • Deleting an instance of an appended scene resulting in an incorrectly saved .vantage file
Memory
Fancy Bullets
  • Excessive shared GPU memory usage with certain large .OBJ scenes
Environment
Fancy Bullets
  • HDR rotation not importing with vrscene generated from Revit
Non-vrscene files
Fancy Bullets
  • TerraGen (.ter) files doesn't import
UX
Fancy Bullets
  • Camera view getting reset to the original camera after placing an asse
  • Pressing ESC while using Place tool makes selected object to be unselectable
  • Issues when switching between Still and Sequence in the Render setup dialog
