The V-Ray Back to Beauty Render Element expands Element expands as all beauty elements for the actual rendering. In the VFB, this render element creates a folder in Composite named Back To Beauty containing all elements with the appropriate blend modes. The elements that will be used for the beauty rebuild are - Background, Lighting, Global Illumination, Reflection, Specular, Refraction, Self Illumination, Caustics, Subsurface Scattering and Atmosphere.
UI Text Box | ||
When selecting the Affect All channels option of Generic material, be aware that the information of the respective component will affect all render elements, therefore the Back to Beauty composition will not match the RGB result from the renderer. |
UI Path
Section | |||||||||||||||
