Extension | Read | Write | Description |
OpenEXR | Chaos Player supports Multi-channel and multi-part OpenEXR images as inputs. Chaos Player only supports writing to single-channel EXR files. | ||
VRIMG | Chaos V-Ray's proprietary image format is supported as read-only. | ||
PNG | The Portable Network Graphics format. | ||
JPEG | The Joint Photographic Experts Group digital image file interchange format. | ||
TIFF | The Tagged Image File Format. | ||
TGA | The Truevision TARGA raster graphics format. | ||
SGI | The Silicon Graphics Image format for raster graphics. | ||
CIN | The Kodak Cineon digital film format is supported as read-only. | ||
DPX | The Digital Picture Exchange format, extended from CIN. | ||
BMP | Microsoft's Bitmap image files are supported as read-only. | ||
DDS | Microsoft's Direct Draw Surface format is only supported as read-only. | ||
HDR | Radiance HDR image files are supported as read-only. | ||
PIC | The PICtor raster image format is supported as read-only. | ||
PSD | Chaos Player flattens all layers when reading Adobe's Photoshop Document format. This format is supported as read-only. | ||
RLA | The Wavefront RLA raster image format is supported as read-only. | ||
RPF | The Raster Product Format is supported as read-only. | ||
TX/TEX | Tiled mip-mapped .tx/.tex TIFF files are supported as read-only. |
UI Text Box | ||
VRIMG is a Chaos proprietary file format used by the V-Ray Frame Buffer (VFB) to store the rendered image incrementally (bucket by bucket) while rendering in full floating-point format, with all available render elements. It is used as a render output but it is not recommended to use it as a texture file format. VRIMG contains metadata, i.e. render statistics. It supports dynamic bucket size. VRIMG can be saved just as any other image format – it can either be the render output format or it can be saved from the VFB. |
Audio file formats
WAV | IBM and Microsoft's Waveform Audio File Format can be used to extract the audio from a video file or replace the audio track in composition. |
Project interoperability formats
