HideElements | ||
There are many places in Phoenix where you can insert a texture and affect the simulation or rendering of fluids - fire/smoke or liquids:
In this page we will go over everything you need to know about texture mapping in Phoenix.
Maya texture mapping specifics
Also, please note that when you need to use a texture as a mask, and not as a source of RGB colors, you need to enable the Alpha Is Luminance option of the texture - this is needed in Sources, Tuners, and mapping the opacity of Fire and smoke.
Phoenix TexUVW
When you want your texture to move together with the fire/smoke or liquid, you need to simulate with Phoenix's Texture UVW.
