Key | Description |
path (string, required) | Specifies path to a .vrscene file. |
colorCorrectionsFile (string) | Specifies path to a color corrections file. |
frameRange (string) | Defines a frame range for the animation. Only makes sense if the scene is actually an animation. |
frameStep (int) | Defines a frame step for the animation (default 1). Only makes sense if the scene is actually an animation. |
height (int) | Defines the height of the rendered image. |
width (int) | Defines the width of the rendered image. |
name (string) | Specifies a name for the rendering job. |
onlyCPU (bool) | Use only CPU for rendering. Applicable for GPU scenes. |
onlyUpload (bool) | Upload the scene and leave the job in paused state. |
Multicamera Submit
Fancy Bullets | ||
Code Block |
$ ccloud job --json submit --sceneFile still.vrscene --allCameras |
This is the result:
Code Block |
{"status":"success","type":"analyze step"} {"status":"success","type":"validate step"} {"type":"progress","progress":0} {"type":"progress","progress":100} {"jobID":"Gpk1UxX0tMdX7d-S","jobURL":"https://cloud.chaos.com/jobs/Gpk1UxX0tMdX7d-S","message":"Scene uploaded successfully. Job ID: Gpk1UxX0tMdX7d-S\nCheck the rendering progress on https://cloud.chaos.com/jobs/Gpk1UxX0tMdX7d-S","type":"output"} |
Fancy Bullets | ||
Code Block |
ccloud job --json submit --sceneFile cams.vrscene --camera VRayCam001 |
This is the result:
Code Block |
{"jobID":"Jpg9RRG6XIWwSzV-","jobName":"cams","jobURL":"https://cloud.chaos.com/jobs/Jpg9RRG6XIWwSzV-","message":"Job created.","type":"output"}
{"message":"Uploading started.","type":"info","uploadSize":"0.00B"}
{"jobID":"Jpg9RRG6XIWwSzV-","jobURL":"https://cloud.chaos.com/jobs/Jpg9RRG6XIWwSzV-","message":"Scene uploaded successfully. Job ID: Jpg9RRG6XIWwSzV-\nCheck the rendering progress on https://cloud.chaos.com/jobs/Jpg9RRG6XIWwSzV-","type":"output"}
Fancy Bullets | ||
Code Block |
ccloud job --json submit --sceneFile cams.vrscene --camera VRayCam001 --camera VRayCam002 |
Built-in Help
The Chaos Cloud Client App binary includes an extensive built-in help for all of its commands and subcommands. Use the --help flag to see it. To see the top-level help:
