Section | ||||||||||||||||||||||||
UI Expand | expanded | true|||||||||||||||||||||
Workflow
Basic Parameters
Anchor
Example:
This example shows how applying multiple reference objects affects the mesh. Click on the expandable field to see the original reference geometries and the order they were used in. A V-Ray Light material with varying Opacity is applied to the reference objects.
title | Expand for reference geometries |
Tiling
The following example shows how Enmesh is used on a simple plane to coat it with a pattern of torus objects. The pattern is controlled via the Tiling parameters and the tori are included in the Reference Objects list.
The Crop box X, Y and Z are set at the following values respectively: 3.15, 1.125, 4.4.
Anchor | ||||
The tiling pattern changes considerably when Tiling values change:
Section | ||||||||||||||||||||||||||||||||
Fancy Bullets | ||
