Note that Chaos Cosmos is not included in the V-Ray for Maya Portable installation file. You can separately download and install Chaos Cosmos.
To use the Chaos Unified Login (a single login into whichever Chaos application grants access to all Chaos applications) with V-Ray portable installation, download and install separately.
When using V-Ray from a Portable installation, the EULA needs to be accepted to start a render. A pop-up window will prompt you to accept the EULA the first time you start a render. Batch rendering is an exception to this.
UI Text Box | ||
If you are using a V-Ray version older than V-Ray 6, please refer to the Installation from zip guide, as the Portable Installation is not available for those V-Ray versions. |
Unpack the installation into a suitable location, which you can later use to run V-Ray on any computer. Here is a detailed step-by-step guide:
Tabs Container | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
The list or variables to set requires unpacking the same installation build. Read the Unpacking the installation file section for more details.
Tabs Container | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
