Tabs Container | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor Environment setup Environment setup
UI Expand | |||||
Setup for V-Ray Standalone
The [STDROOT] and [PLUGINS] tags in the script are typically replaced with their respective directories by the V-Ray installer. However, if you are using a version earlier than V-Ray 6, update 1, and performing a portable installation, you need to manually replace these tags. The [STDROOT] tag needs to be replaced with the full path to the vray folder in the portable file. The The [PLUGINS] tag needs to be replaced with the full path to the maya_vray folder in the portable file. The tags are located in the following files:
If you want to use any additional tools like the standalone denoiser, or the VRIMG to OpenEXR converter, etc., then also add <unpacked_location>/vray/bin to the PATH environment variable.
UI Text Box | ||||
