The Particle Texture is a 3D texture, and which can be created from the Hypershade in Maya. It reads particles and colors the positions of each particle in a particle system.
UI Text Box | ||
You can also turn particles into a a 3D mesh, by using the Particle Texture as a Surface Channel texture in the Rendering rollout. This gives you additional flexibility for shading particles, to achieve more advanced effects. For example, you could use the Particle Texture to mesh specific particles based on their RGB color, which would make it possible to create effects like mixing together a solid and transparent liquid, using two meshes. |
