Distance – Specifies a radius outside which all points are shaded with Far Color.
Far Color – The color returned by the texture for points that are at a greater distance than the Distance value from objects specified in the list.
Near Color – The color returned by the texture for points that are right at the edges of the object(s) specified in the list.
UI Text Box
type
info
For points that are outside or inside the objects but not exactly next to them, the color is determined by blending between the Near Color and the Far Color while the distance serves as a falloff radius.
Add Objects – Adds preselected objects from the scene.
Inside Separate
Inside Separate – When enabled, the Near Color is overridden by the Inside Color value for points that are inside the specified geometry.
Inside Color – The color returned by the texture for points that are right inside the object(s) specified in the list.
UI Text Box
type
info
For points that are inside the objects but not exactly next to them the color is determined by blending between the Inside Color and the Far Color while the Distance value serves as a falloff radius.
Inside Solid – When enabled, all points inside the specified geometry are given the Inside Color and no blending is performed.
Outside Separate
Outside Separate – When enabled, the Near Color value is overridden by the Outside Color value for points that are outside the specified geometry.
Outside Color – The color returned by the texture for points that are outside the object(s) specified in the list.
Outside Solid – When enabled, all the points outside the specified geometry are given the Outside Color value and no blending is performed.
width
5%
width
35%
Example: Refine texture placement with Distance texture
