UI Paths
Section | |||||||||||||||||||||||||
Creating V-Ray Enmesh
Section | |||||||||||||||||||||||||||||||||||
Randomization with Multi-Sub Texture: Get ID from set to Random by Instance ID
Examples
Reference Object used for building a pattern:
The geometries which are repeated are the parts of the Reference Object which are inside of the Bounding Box. By default the Bounding Box encloses all the Reference Objects added.
The Bounding box can be changed with the Spacing X, Spacing X and Spacing Z parameters. Positive values for Spacing increases the Bounding Box of the Reference Objects
and this way creates distance between the items. Negative values clip away parts of the Reference objects.
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
Footnotes
Section | |||||
